10 members (Hotrod Lincoln, mason86, ndkid275, Paul Mullen, Hawkman, Ponchogl, wilbur53, Rusty Heaps, 49choptop, 1 invisible),
91
0
Mod | | | Forums66 Topics128,050 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Can someone out there please help me understand if there is any difference between a 47-53 216ci automobile engine and a 47-53 216ci truck engine, other than identifying serial numbers on the block? Chevy went to the trouble of segregating them via ID #'s, but is that the only difference? Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 216 blocks, heads, and intake/exhaust manifolds were the same on cars and trucks. Parts attached to the above parts might have been different on cars and trucks.
Pre '68 Dave will straighten this post out, if it is wrong.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think the front mounts were different, the car may have had an automatic choke. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Horsepower went up on the car 216 engine to 92 hp in 1950 or so. The trucks seemed to stay at 85 hp, or at least that is what the id plate says on the 1953 Chevy I have. Whether the cams may have had a little different grind to give the truck engine a more broader torque curve than the car? John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is little difference in pass and truck 216 engines. My 1950 parts book shows the same cam, lifters, distributor, head, and carb. The only thing that comes up different is the pistons. Truck pistons are a little bit heavier than pass pistons.
Horse power went up in 1950 as Chev went to Rochester carbs that year, and exhaust valve and seat angle went from 30 degrees to 45 degrees for better flow.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | The fuel pump is different between car and truck engines. The fuel line connectors are in different locations.
Jim
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Up to 1951 car and truck fuel pumps were the same. Starting in 52 when cars got side mounts there fuel pumps angled the in and out to clear the mount.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | This is a useful link . See page 3 for front mounts. I think the car engines had the fiber camshaft gear and trucks were aluminum...
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You are correct, Frank50, except for the Corvette 235. It had a metal/aluminum cam gear - but, I guess that a Corvette aficionado would say a Corvette is not just a car.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have been searching for a reason trucks got aluminum gears and cars got fiber. I have thought it was because fiber was quieter, but an aluminum gear installed correct with no run-out seems to be silent also. Since truck and cars used the same cam, lifters, and head(in 216's anyways) I can not come up with a reason Chev did this. Any ideas?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Well I have been wondering about the differences in the angle of the fuel pump lines on one of my engines now I know the block was cast with provisions for side mounts but front mount was used. Thank you for that little bit of info. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I think the aluminum cam gear was concidered to be more Heavy Duty. My 1957 322 Buick engine has double roller timing gear set while the cars had single... Mike B  | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | yep, the aluminum never wore out, but you could'nt go 100,000 miles with a stock fiber gear. Many high mileage pass motors would lose their fiber gears. If you can compare side by side you can usually hear the alum gear's slight noise. Not a big deal.
Even in the next generation sixes, 194/292, the trucks use aluminum gear on cam. | | |
