| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 13 New Guy | | New Guy Joined: May 2012 Posts: 13 | Can anyone tell me where the bed to frame ground is on a '58 Chev Apache half ton? After 54 years it all looks to be one color underneath.
Thanks, Mike
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there wasn't one from the factory, if all the bed mount hardware is clean and tight there will be a ground thru that, but if you're having problems with the lights, what most folks do is just add a wire from the rear cross sill [which is welded to the bedsides] to the frame .... you might also want to clean the factory attachments from the battery to cab and engine to cab
Bill | | | | | Joined: May 2012 Posts: 13 New Guy | | New Guy Joined: May 2012 Posts: 13 | Hi, Unfamiliar with rear cross sill?
Mike
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's a number of channel pieces supporting the floor from side to side, they're called cross sills, the rear most one, where the boards end and below where the tail lights mount to the stake pocket, is welded to the bed sides - it's also bolted to the frame
Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Any good woven ground connected from the frame to the bed will do. FYI grounds are like money, you can never have too many.
~Jim
