0 members (),
80
Mod | | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 10 New Guy | | New Guy Joined: Oct 2007 Posts: 10 | Just picked up a 72 chevy from california. Has the 402 BB.First trip out with a good sized trailer behind I was loosing power as it got warmed up.I had seen there were wire problems back at the coil hookup, so I put new wires to it,at start the 12V was there, but at run I was down to 5-6V.On my maiden trip when it was loosing power I hot wired the coil to get 12V and it helped a lot. What should the Voltage be to the coil at run, and is there a resistor wire out there available or should I go HEI and forget the problem. Thank You
Dennis M
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | If you don't have an HEI you have a resistor wire. I couldn't find a wire diagram online. IIRC you should have two wires to the hot side of the coil. One from the solenoid this is 12v at start only. The other is from the firewall and is the resistor wire. 5-6v sounds a little low, I'm thinking it should be closer to 9v. HEI is the answer, but it will be a tight fit between the distributor cap and firewall. You will also need to replace the resistor wire and the wire back to the ignition switch with 12 gauge, 10 gauge would be fail safe. Do a search there is plenty of post on how to make the change.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
