4 members (greenie-reddy, Jon G, cmayna, dt235sd), 26 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#868322 07/21/2012 3:33 PM
I am working on installing the engine into my 1954 3100. I have gotten new mounts, I believe that I understand how to install the rears but I want to be sure, they consist of 2 components, a flat mount with a metal side and a rubber side and a "u" shaped mount with a metal side and a rubber side. I believe that they are supposed to sandwich the cross-member with the "u" shaped mount on top and the flat one underneath with the rubber side contacting the cross-member. If anyone would have access to a diagram or know the correct procedure to install the mounts it would be greatly appreciated, Thank you!
'54 Shop Manual Engine Mounts
< CLICK SHOP MANUAL>
Here is the '54 Factory Assembly Manual diagram for rear and front mounts:
< CLICK FAM >
You will need the bolt locks for the rear mount. See source in my "saga" below.
Here is my motor mount saga (mostly front mount):
< CLICK SAGA >
Buy a Shop Manual, a Factory Assembly Manual, and an Accessories Installation Manual for your truck. Available at most suppliers.
- Lonnie
My '54 3104
