0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I have looked under tech tips, and searched the forums to no avail. Any guidance would help in replacing a cracked side glass. This is for a 54 1/2 ton cab with wing windows if that matters. Thanks! | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | You have to remove the vent window frame assembly, purty easy from there. Becareful when re-installing the vent assembly, the new glass upper front corner subject to crack if to much pressure applied. | | |
