8 members (Ponchogl, Bill Hanlon, MickeyP, Hotrod Lincoln, Hanks custodian, Otto Skorzeny, Charles in CA, 48ed56pam), 172 guests, and 1 robot.
Topics128,081
Posts1,056,071
Members48,434
I have looked under tech tips, and searched the forums to no avail. Any guidance would help in replacing a cracked side glass. This is for a 54 1/2 ton cab with wing windows if that matters. Thanks!
1946 Chevrolet 1/2-ton
More pix on Photobucket
Y
Y Offline
You have to remove the vent window frame assembly, purty easy from there. Becareful when re-installing the vent assembly, the new glass upper front corner subject to crack if to much pressure applied.
