0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | I'm looking to replace my master cylinder and started looking at the brake power boosters on classic parts and am leaning in that direction. Question is can I use a disc/disc booster on a drum/drum setup? I'd like to convert over to disc/disc later and don't want to buy twice. Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy New_Ton, yes you can use the disc/disc master cylinder in a drum/drum application IF you use a resisdual pressure valve for drum brake application (I think 15 p.si.)in each brake circuit. When you convert over to disc brakes you can remove the resisdual pressure valves, I would also add a compensating valve to the system when converting to disc brakes, hope that helps | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The booster would likely be the same for both set ups. It's the master cylinder that would be different. The disc/drum MC has a built in residual valve which is required for the drum system. However, many aftermarket suppliers provide a Corvette MC with all of their applications. In this case you will need a separate residual valve for the rear. They should be available through most suppliers of the other parts. You will probably find that it is unneccesary to change to 4 wheel discs, changing the fronts will be a vast improvement. I installed a dual diaphram booster and dual MC on a 55 one ton and the brakes were super. They have 12" drums but the main weakness is the cheesy stock master cylinder. Fred
