0 members (),
133
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86793 12/01/2001 6:41 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Could someone tell me the wiring code for the wires that lead from the turn signal switch housing down the column to the two plugs that mate with the jack under the dash. Getting the bugs outa this left side brake/TS light problem is the last thing (knock on wood)I need to resovle before registering 'er. Any assistance is greatly appreciated.
Scott | | |
#86794 12/01/2001 12:27 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I would check the grounds and check for the correct bulb in the socket befor tearing the wireing apart! I believe chevy1 has the wiring diagrams.
[ 12-01-2001: Message edited by: Mechainiac ]
#86795 12/01/2001 6:32 PM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Been there, done it. Problem is no brake/TS on the left side, rear. I have the running light but no brake/TS light. Ground is fine, bulb is OK. I pulled the plug at the firewall and had nothing there so I figured the problem had to be in the switch housing. Took it all apart and the contacts are all wore down. Went to NAPA to get a replacement and the replacement doen't mate up to the cowling. I did plug the two connectors up under the dash and the problem went away, so I know that's what's wrong. Appartently, the common replacement is for Chevy, not GMC. I was thinking that if I had "the blue wire is...." info, I could wire in a Mickey TS unit. | | |
#86796 12/02/2001 4:17 AM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Scott Check the 6066GMC site I think there is a link to diagram there. If not e-mail me off list and I'll send scan of one I have. (it's small and may be hard to read though) Judd [email protected] http://sjmodels.railfan.net | | |
#86797 12/02/2001 4:55 AM | Joined: Sep 2000 Posts: 8 'Bolter | | 'Bolter Joined: Sep 2000 Posts: 8 | My Chev had the aftermarket switch and wiring when I got it, so I don't have a clue how it works on the original. Getting the aftermarket switch won't necesarily resolve your problem as I am still waiting for someone with more knowledge, skill or whatever to come help me fix mine. The truck has been sitting in the garage for over a month in beautiful pristine red and white condition because of this! :mad:
Ivy Red 2021 Buick Encore GX. Down to new low on the cylinder index (4)!
I don't have my 1965 Chev 1/2 ton anymore, but it is still in the gallery if you are interested.
Blackdog died 2009. Now my only dogs are at brothers' place!
#86798 12/02/2001 10:51 PM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Well, I did it. I went and put the aftermarket switch setup on. Actually, figuring out the wiring was easy. Everything works great, front and rear, and I also have emergency flasher operation! I have the wiring "guzintas" if anyone is interested. Thanks for the input. Scott  | | |
