| | | Forums66 Topics128,205 Posts1,057,429 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 49 | I drive my 1949 Chevy Truck about a 100 miles per weekend. I have to put a quart of oil in every 300 miles or so. It isn't smoking, but underneath the pan and vent tube side its all oily. I've had all the gaskets replaced. It runs great, I put about 4,000 miles a year on it just running around. I want to correct this, can this be done, or do I need to rebuild the engine? Where's it leaking all the oil from?? SIG | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have seen many times where lock washers were used on the fuel pump mounting bolts and oil wicks out the bolts and through the split in the washers. I have also seen where the fuel pump arm pivot pin has come loose in the housing allowing oil to leak out. Just two of many possibilities.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2012 Posts: 19 New Guy | | New Guy Joined: May 2012 Posts: 19 | Put sheets of newspaper under it when it's parked to see if its really leaking, and maybe from where.
When new, those 216 engines did normally use about 1 quart per 1000 miles, so honestly --- it also took a long time to break those rings in , and 1 quart per 300 miles wasn't unusual for breakin-in. If you can't find the leak, and it runs OK, I would live with the quart of oil when needed. Cheaper than a rebuild. But check your compression just to be sure. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Also have a look at the front right bottom of the motor to see if the oil is leaking out the front and blowing back along the side. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Mine's always wet. Misted on the top and bottom. No dripping other than the vent tube tho. I've heard before that 'if a 216 isn't wet, you're out of oil.' | | |
