| | | Forums66 Topics128,105 Posts1,056,538 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 22 New Guy | | New Guy Joined: Jul 2012 Posts: 22 | Hey guys! I've been googling and searching for almost two hours. Best i can tell it's a direct swap.
Could someone verify that for me?
Chuck
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | | | | | | Joined: Jul 2012 Posts: 22 New Guy | | New Guy Joined: Jul 2012 Posts: 22 | Holy crap! You wouldn't believe how many times i saw that question in my research. Yet i still made the noob mistake.
47 3/4 ton to 48 1/2 ton | | | | | Joined: Jul 2012 Posts: 22 New Guy | | New Guy Joined: Jul 2012 Posts: 22 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is the 47 a First series or second? If it is a second series 47 you should have no problem mounting everything but the box. 47 second series do not have a indentation in the dash for column shift but that should not be a problem if you use a 1948-54 4 speed trans.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2012 Posts: 22 New Guy | | New Guy Joined: Jul 2012 Posts: 22 | Thanks Pre '68 Dave.
I really haven't figured out how to tell if it's a first or second series. I'll start researching that. Seems with every question I have it just leads me to 5 more questions. | | | | | Joined: Jul 2012 Posts: 22 New Guy | | New Guy Joined: Jul 2012 Posts: 22 | I'm guessing it's a second. All the parts minus the gas tank location look just like the 50-54's. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't guess, a 1st series 47 body looks like a 41-46 because they're really "left over" 46's, the 2nd series "true 47" is an AD, like 48-53 .... yes, the sheet metal from a 3/4T will fit on a 1/2T chassis, might need to jig some mounting spots a bit
Bill | | | | | Joined: Jul 2012 Posts: 22 New Guy | | New Guy Joined: Jul 2012 Posts: 22 | That's what i was figuring out. So she's defiantly a AD. Thanks for the help guys. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I know 1948-54 cabs mount on each side in the front, I assume 47 is the same. I was just working on a 48 and the rear cab mount is in the center on what looks like a rocking set-up, I would bet 47 is the same. Later cabs use a shackle set-up, on each side, off the outside of the frame up to the cab floor.
