7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert), 99 guests, and 1 robot.
Topics128,137
Posts1,056,430
Members48,441
#867394 07/17/2012 11:45 AM
Has anyone had trouble with installing Jim Carter rear and corner glass rubber seals on 47-53 chevy trucks. I fought mine for hours, and gave up. I took the truck to my body man, And he's having trouble. He thinks the slit that goes to the body is not deep enough on the after market seals. Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Is the glass original or aftermarket?
Luckily I have not had to do the corner glass but I have read about poor fitting glass.
The glass is original.
...link...
post #23 in the link above describes a problem with a seal kit "counterparts" brand
hopefully someone will be along to suggest a good kit for you
I used STEELE rubber for my windshield
My body man got them in. using some of the original rubber with the new locking strips. So anyone doing this, Be sure to buy a good american made rubber seal. You can save yourself alot of frustration. Terry
