8 members (‘37ChevyPU, Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, 1 invisible),
81
Mod | | | Forums66 Topics128,139 Posts1,056,451 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Has anyone had trouble with installing Jim Carter rear and corner glass rubber seals on 47-53 chevy trucks. I fought mine for hours, and gave up. I took the truck to my body man, And he's having trouble. He thinks the slit that goes to the body is not deep enough on the after market seals. Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is the glass original or aftermarket?
Luckily I have not had to do the corner glass but I have read about poor fitting glass. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 |
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...link... post #23 in the link above describes a problem with a seal kit "counterparts" brand hopefully someone will be along to suggest a good kit for you I used STEELE rubber for my windshield | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | My body man got them in. using some of the original rubber with the new locking strips. So anyone doing this, Be sure to buy a good american made rubber seal. You can save yourself alot of frustration. Terry
