3 members (Patharr, KEVINSKI, 1 invisible),
236
Mod | | | Forums66 Topics128,108 Posts1,056,230 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86704 06/21/2004 8:53 PM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Would it be better to:
a) replace the heater motor with a 12 volt replacement, b) have the current one altered to accept 12 volt, or c) install a voltage reducer and leave it original.
Thanks for your suggestions. | | |
#86705 06/22/2004 1:28 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I don't think it is feasible to convert a heater motor to 12V, but I could be wrong. Using a resistor is unpractical for a heater motor. You can get DC-DC convertors for probably equal to or more than buying the 12V motor. I'd buy the 12V motor.
Jason
#86706 06/25/2004 3:24 AM | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | I have a 12v-6v reducer on my heater and it works great. Just get one that has a built in heat sink to dissipate extra heat build-up. I think it cost ~$7.50.
I can't drive 55... no really, I can't!
#86707 06/25/2004 12:44 PM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | How long ago did you do it and how often do you use it? I don't expect to use mine much, as the truck wil be parked in the winter. We get some cold mornings and evenings, so it would be nice to have. Price sounds good too.
Thanks! | | |
#86708 06/25/2004 3:25 PM | Joined: Jun 2004 Posts: 25 Junior Member | | Junior Member Joined: Jun 2004 Posts: 25 | I got mine at Amican Classic Truck Parts, Although I notice it is $15 not $7.50. THe truck was converted to 12V about 2 years ago and it is driven nearly daily year round. I have run the heater for over an hour with no troubles at all.
#86710 06/25/2004 11:01 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Does your 6v heater have a 'speed' control? Most Chevy heaters had a 3 speed, or a variable control.
If you do, then you actually already have a voltage reducer. I'd guess that a 12v supply to a 6v heater motor running at 1/2 speed has the same rpm as 6v supply to a 6v heater motor running at full speed.
I'm not sure this is exact, but DC motors in general have a really wide latitude in supply voltage. Of course, running a 6v motor at 12v high speed will run hotter than with a 6v supply.
Personally, I'd run the 6v motor on high speed for 5 minutes or so (with the motor cold and not running) - then see how hot the motor is actually getting. Any potential damage to the motor in this situation will likely be from heat - melting solder, etc.
If you do this, make sure the heater motor has an appropriate fuse for safety in case of motor failure. | | |
#86711 06/26/2004 12:30 AM | Joined: Mar 2000 Posts: 1,178 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,178 | I rebuilt my heater and replaced the original 6 volt motor with a 12 volt motor that I ordered from Grainger online http://www.grainger.com/Grainger/wwg/start.shtml . You may not be able to buy directly from them like I did, but you can determine what motor to get there and pick it up at any electrical supply store locally. I think I paid about $20 bucks for mine, and it fits and runs just fine. If you decide to rebuild it, make sure to have the heater core pressure tested and repaired if it leaks.  | | |
#86712 06/26/2004 1:43 AM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | I used a reducer and a 12 volt three-speed switch with the 6 volt motor at first. Between the resistance in the switch and the reducer the motor ran fine and cool. However, top end speed was fine, but middle and slow were very poor. I'm going to remove the reducer when I get a chance and see what happens with just the switch. From past experience, I'll make certain to keep my fire extinguisher handy.
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#86713 06/29/2004 2:43 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I've been running a reducer between source and my variable heater switch for a couple years it it works great. Have noticed since the beginning that the top speed is too fast and I'm concerned that I'll burn the 6 v motor so I use the lowest speed which is about the same as the original's top speed. Lots of heat.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
