1 members (2-Ton), 92 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
Hey guys! I've been googling and searching for almost two hours. Best i can tell it's a direct swap.
Could someone verify that for me?
Chuck
3/4 to 1/2 what?
1951 1 Ton Completed
Holy crap! You wouldn't believe how many times i saw that question in my research. Yet i still made the noob mistake.
47 3/4 ton to 48 1/2 ton
Anyone?
chuckNpah #867280 07/16/2012 10:00 PM
Is the 47 a First series or second?
If it is a second series 47 you should have no problem mounting everything but the box.
47 second series do not have a indentation in the dash for column shift but that should not be a problem if you use a 1948-54 4 speed trans.
My Blog
Thanks Pre '68 Dave.
I really haven't figured out how to tell if it's a first or second series. I'll start researching that. Seems with every question I have it just leads me to 5 more questions.
I'm guessing it's a second. All the parts minus the gas tank location look just like the 50-54's.
don't guess, a 1st series 47 body looks like a 41-46 because they're really "left over" 46's, the 2nd series "true 47" is an AD, like 48-53 .... yes, the sheet metal from a 3/4T will fit on a 1/2T chassis, might need to jig some mounting spots a bit
Flxible #867478 07/17/2012 6:45 PM
That's what i was figuring out. So she's defiantly a AD. Thanks for the help guys.
I know 1948-54 cabs mount on each side in the front, I assume 47 is the same.
I was just working on a 48 and the rear cab mount is in the center on what looks like a rocking set-up, I would bet 47 is the same. Later cabs use a shackle set-up, on each side, off the outside of the frame up to the cab floor.
My Blog
