0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 5 New Guy | | New Guy Joined: Apr 2011 Posts: 5 | Does anybody know the valve stem height for a 1955 235 with soild lifters as measured from spring pad to end of valve?I need intake and exhaust. Head had been rebulit and was worn out so I did not want to go off of old parts. I have bigger intake valves and installed ex seats and new valves. I can grind seats to propper height. Thanks John | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The assembled height of the valve springs for a solid lifter 55 engine is 1.86". You can measure the distance on a new valve with the spring retainer and keepers installed from the underside of the retainer to the top of the stem, and add that to the spring height specification to get a target dimension to work with. Hydraulic lifter engines use a 1.84" spring height dimension. Jerry
| | | | | Joined: Apr 2011 Posts: 5 New Guy | | New Guy Joined: Apr 2011 Posts: 5 | That will work thanks intake a lot longer!! thanks again John | | |
