2 members (klhansen, Samantha), 51 guests, and 2 robots.
Topics128,053
Posts1,055,778
#866847 07/14/2012 11:16 PM
I recently add an Oil Canister set up... Should I be using detergent oil now ?
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
healingbear #866892 07/15/2012 12:51 PM
If you search, you find a thousand posts, and a hundred ideas on this subject. For what it's worth, before I switch to detergent oil, I pull the pan and clean out the sediment, but that's a good idea anyway. Detergent oil won't suddenly lift the sediment out.
Also, for what it's worth, in my '49 Pontiac manual, they suggest slowly switching, you know running half and half for a couple of changes, then using all detergent oil.
I'm sure others will have differing opinions!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
