5 members (Otto Skorzeny, Wickedbass, Hanks custodian, 32Fordpuchoptop, Gdads51), 67 guests, and 2 robots.
Topics128,094
Posts1,056,048
Members48,433
Is there a common dual master cyl. used for conversion into a 46 GMC , Chevy can't be much different ? Looking for advice and suggestions .
Allan
1946 GMC
1949 Mercury M68
3B Offline
Hy red1946, if you could give us a bit more information we could better answer your question, size of truck, stock drum brakes or upgrade to front discs or full disc brakes? There are a few suppliers for retrofit master cylinder kits, have a look at their websites, hope that helps.
Sorry . 46 GMC 1/2 ton . Willave a 4.3 litre V6 and a T5 trany with an S10 rear end . plan to leave the front end stock with drum brakes .
Allan
1946 GMC
1949 Mercury M68
Hey,red1946 If you are going keep the drum brakes I would consider upgrading to Bendix style.I swapped my Hucks to Bendix on my 46 one ton and the difference is night and day.Also the newer parts are available at any flaps.Not sure about master cylinder but I will follow this thread as I would also like to upgrade that as well.
Really need to have "matching" brakes all the around.
I'd look for a "drum/drum" master with the same bore size as what you have now. Don't use a master for disk brakes! Talk to someone at your flaps and look the books for the mid-late '60s cars. Also '69-'70 Chevy and GMC light trucks.
best wishes,
Les
It seems there are all sorts of options for 47 and up. But for the 41 to 46 there are no master cylinder conversion kits or replacements. It must be due to the odd mounting of the MC on the 3 speed transmission. I would like to upgrade to discs and dual MC, but there is nothing that "bolts in".
Thanks guys sounds like good advice . One question , I am not familiar with the term ( flaps ) .
Allan
1946 GMC
1949 Mercury M68
Friendly Local Auto Parts Store
The solution here is to get the clutch and brake pedal setup from a larger truck of the era. The MC was frame mounted, with the actuator rod facing toward the rear of the truck.
The set up worked like this, when the brake pedal was pushed, a rod and clevis was attached to it in a way that created a pulling motion on the rod. This rod pulled a frame mounted lever towards the front of the truck. A shorter rod was also attached to this frame mounted lever that would in turn push the MC.
This sounds really complicated, but it is really a simple setup. Many after market frame mounted MC brackets can be made to work with or without a booster.
Thanks . To simple ,I have a love /hate relationship with acronyms . dang
Allan
1946 GMC
1949 Mercury M68
