| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86669 12/28/2004 4:15 PM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | This is a 53 1/2 ton with original dimmer switch. I am replacing with a repop. Haven't removed the original yet, but there are three wires on the original. The repop has three terminals labeled: L, 1 and 2. I'm assuming that one is the power and the other two are the low beam and high beam. Can anyone tell me which wire goes where on the replacement part? Thanks | | |
#86670 12/28/2004 11:10 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | You can use your VOM to bench test the new switch and figure out the connections before installing it. Check the resistance between the terminals to determine which two are connected. Click the switch and check again. One terminal will be common (connects to another terminal) in both tests - that's the one that connects to the light switch. The other two terminals connect to the low & high beams - doesn't matter which one goes where.
Gord 1954 1/2 ton 235 4 speed
