0 members (), 50 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
I plan to install an S10 rear end in my 46 GMC 1/2 ton . Also currently searching out possibilities for a manual dual master cyl. conversion . What if anything can be done to improve the front brakes while still maintaining the original suspension ?
Hope that made sense . Your thoughts would be appreciated .
Allan
1946 GMC
1949 Mercury M68
Riding in the Passing Lane
The easiest upgrade is to get the backing plates & brakes from a 51 up Chev/gmc 1/2 ton. They are the Bendix style & are better brakes, Easier to work on & better parts availability the the old Huck brakes. You probably want to get a disc brake kit & use the 5 hole 4 3/4 pattern like the rear end has.
1972 Chevy c10 Cheyenne Super
Are the spindles the same ? Oh yea 51 up to what year . would early 70's disc brakes work ?
Allan
1946 GMC
1949 Mercury M68
Many kits are available for short money to put either 5 or 6 lug disc brakes on the stock 46 front axle. Check with the usual suppliers... Jim Carter, Bowtie bits, the Filling Station, Patrick's, etc...
The Master cylinder mounting will have to be custom.
