1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#86649 04/16/2003 11:22 PM
Inside my horn, there is what appears to be a burnt-out capacitor. Is there a source to get a horn repaired or does anyone have a source for the capacitor. The horn is from a 52 Chevy 1/2 ton.
#86650 04/17/2003 1:26 PM
I've never looked inside one of these, but in my limited experience of repairing electronic stuff, generally any capacitor that is rated for the voltage you have and is close to the microfarad rating (within 20% or so) will often work fine. Can you read the values on the cap you have? Is it sodered in or have legs that are bolted on? There are some guys on this board that really know this stuff...maybe they will pitch in here.
Good Luck
#86651 04/17/2003 2:22 PM
I am umable to find anything written, but it is soldered in.
#86652 04/17/2003 2:49 PM
Try a .5mf 50v capactor, it's there for the same reason as the condensor in the distributer, to stop the points from burning..
