1 members (DaveV),
109
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86649 04/16/2003 11:22 PM | Joined: Nov 2001 Posts: 14 Member | | Member Joined: Nov 2001 Posts: 14 | Inside my horn, there is what appears to be a burnt-out capacitor. Is there a source to get a horn repaired or does anyone have a source for the capacitor. The horn is from a 52 Chevy 1/2 ton. | | |
#86650 04/17/2003 1:26 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | I've never looked inside one of these, but in my limited experience of repairing electronic stuff, generally any capacitor that is rated for the voltage you have and is close to the microfarad rating (within 20% or so) will often work fine. Can you read the values on the cap you have? Is it sodered in or have legs that are bolted on? There are some guys on this board that really know this stuff...maybe they will pitch in here. Good Luck | | |
#86651 04/17/2003 2:22 PM | Joined: Nov 2001 Posts: 14 Member | | Member Joined: Nov 2001 Posts: 14 | I am umable to find anything written, but it is soldered in. | | |
#86652 04/17/2003 2:49 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Try a .5mf 50v capactor, it's there for the same reason as the condensor in the distributer, to stop the points from burning.. | | |
