8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna), 154 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#866442 07/12/2012 3:54 PM
Having trouble getting wheels to fit my 54 3600 with original tie rods. I have read switching to 1 ton tie rods from Autozone for around $20.00 is an answer. I find the price to be $58.00. What is the application that I ask for? I have found Accuride Wheels #29576 with 4 1/4" backspacing that I think will work with a 1/4" spacer. I found these thru Rickson Wheel
Thanks again
Tony
go to search and put in dexstar wheels,lots of info there.It helped me very much to solve my wheel and tire issues.
I have modern tie rod ends on my truck. The drag link uses the same ones, so my truck uses 4 total. The draglink and tie rod are custom made. It does eliminate the problem of backspacing.
If you use 1 ton tie rod ends for 1954, you won't be able to connect them to your tie rod. The 1 ton uses a different tie rod length and thread diameter/pitch.
Your options are: 1) different wheels, 2) spacers, or 3) custom setup like I have.
