1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#864895 07/07/2012 2:35 AM
I tried a search could'nt find anything about the headlight relay some made by delco, was wondering what years they used them if it was a dealer accessory I dont see anything on 1940 wireing diagrams showing them Instructions for the relay say something about not enough voltage to the headlights ???
Thanks for any info
crash2012 #864897 07/07/2012 2:47 AM
Last edited by tclederman; 07/10/2012 3:24 PM. Reason: Changed 3.459 to 2.459 - sorry
tclederman #865752 07/10/2012 1:17 AM
I don't see it in that group??
crash2012 #865753 07/10/2012 1:18 AM
3.459 spring-pin-clip,accelerator
crash2012 #865768 07/10/2012 3:30 AM
not sure if this is something you can use but it should work. Headlight relay system
Jolly #865869 07/10/2012 2:00 PM
There's a 6 volt headlight relay on Ebay right now, but it's made for an early Volkswagen. Relays just eliminated long, small-diameter wire runs and reduced the voltage drop, resulting in brighter lights. On a 6 volt system, the difference in brightness was very noticeable, plus light switches and dimmer switches lasted a lot longer.
Thanks, I understand what they were used for and how to hook them up, was just wondering if they they were added by the owner at a later date or if trucks were sold with them as original equipment for my 41 chev
crash2012 #866425 07/12/2012 3:11 PM
Riding in the Passing Lane
41 chevy had no relays. Even the horn was hooked up direct to power & grounded by the button.
1972 Chevy c10 Cheyenne Super
They were added by the owner later.
Roy Rodgers #867714 07/18/2012 9:26 PM
Ok thanks everyone
I use these 6 volt relays from Newark
Ted
My ride but looking for a Deco Bolt for the wife.
