| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | I tried a search could'nt find anything about the headlight relay some made by delco, was wondering what years they used them if it was a dealer accessory I dont see anything on 1940 wireing diagrams showing them Instructions for the relay say something about not enough voltage to the headlights ???
Thanks for any info
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |
Last edited by tclederman; 07/10/2012 3:24 PM. Reason: Changed 3.459 to 2.459 - sorry
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | I don't see it in that group?? | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | 3.459 spring-pin-clip,accelerator | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | not sure if this is something you can use but it should work. Headlight relay system | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | There's a 6 volt headlight relay on Ebay right now, but it's made for an early Volkswagen. Relays just eliminated long, small-diameter wire runs and reduced the voltage drop, resulting in brighter lights. On a 6 volt system, the difference in brightness was very noticeable, plus light switches and dimmer switches lasted a lot longer. Jerry
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Thanks, I understand what they were used for and how to hook them up, was just wondering if they they were added by the owner at a later date or if trucks were sold with them as original equipment for my 41 chev
Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 41 chevy had no relays. Even the horn was hooked up direct to power & grounded by the button. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | They were added by the owner later. | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | | | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | There's a 6 volt headlight relay on Ebay right now, but it's made for an early Volkswagen. Relays just eliminated long, small-diameter wire runs and reduced the voltage drop, resulting in brighter lights. On a 6 volt system, the difference in brightness was very noticeable, plus light switches and dimmer switches lasted a lot longer. Jerry I use these 6 volt relays from Newark
Ted My ride but looking for a Deco Bolt for the wife.
