| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86641 07/21/2003 5:10 AM | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | Hello all. I hooked up two extra tail/brake lights for more visability on my Jap cruiser. Everything was hooked up correctly and the wiring was done right, but i blew a fuse and a bulb the first time i hit the brakes. The stock fuse was a 10 amp for the single bulb. Am i correct to think that it is drawing more then 10 amps now with 2 extra bulbs? I replaced the fuse with a 20 amp and it has been fine, but am i going to fry something with the higher amp fuse being in there? Thanks for any replies!
Oneton
1948 GMC 250 Series Flatbed
#86642 07/23/2003 10:40 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, that is probably a reasonable assumption, if you used bright bulbs. You may want to test that you are really OK by putting a 10A back in and taking the new bulbs out of the sockets to make sure the wiring is actually correct. Be aware that a bike typically only has a 150W or so alternator and it doesn't take many accesories to overload it and then you find it doesn't charge around town. Check your specifications to make sure it can handle the load.
I had a funny problem with my '74 Honda CB750 once. It would blow all the fuses when I hit the brakes and die, but only once in a while. It turned out to be a wire connector under the tank that lost its insulating wrap.
