0 members (),
108
8
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86618 09/03/2004 12:21 PM | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I have found a decent replacement material for the rubber clutch plate in the tuner mechanism. If anyone is interested, I will explain further. | | |
#86619 09/08/2004 3:11 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | I'm interested, please reply.
Winona 1949 3100 5 Window Deluxe Cab
#86620 09/09/2004 1:53 AM | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Thanks for asking! I didn't want to "waste bandwidth" !
The radios of this era use a clutch mechanism which disengages when a station button is pushed, to allow the tuner to move position. The clutch has a metal diaphragm on each side and a thin rubber membrane disc in the middle. The rubber membrane distorts over time with bumps appearing and it results in the clutch slipping, to the point that the tuning doesn't work through the knob. It is difficult to find a suitable replacement for the membrane but I managed to do so.
I cut apart a pair of latex kitchen gloves which are rubber on the outside and some kind of smooth material on the inside. I took a piece and glued two inside surfaces together with contact cement, creating a new membrane with rubber on both sides and having almost identical physical characteristics as the original material. | | |
#86621 09/09/2004 4:35 AM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Great! I never would have thought of that!
#86622 09/09/2004 8:03 PM | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | 49er, just another little hint. On my first attempt at putting contact cement on the glove material, it bubbled up out of shape. On the second successful attempt, I taped the material to a peice of wood, applied the glue and when it was tacky, I removed the tape and stuck it together. | | |
