10 members (John Dlugos, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53, Buckeye998, Chip O),
204
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86613 03/02/2005 6:22 PM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | What is the difference between a 2 and a 3 prong flasher? My new turn signal switch recommends the three prong flasher but my fuse block has a nice new 2 prong flasher. | | |
#86614 03/03/2005 3:17 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | A 2 prong flasher is switched in series with the turn lights, and interrupts the circuit to produce "blinking". The three prong flasher does the same except an extra contact is made available to feed an indicator light on the switch. | | |
#86615 03/03/2005 4:02 AM | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Thanks truckernix. Would there be any problems connecting the two wires from the switch for both the external lights and the ones on the switch? | | |
#86616 03/03/2005 4:28 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know how your switch is wired but if it is meant to use a three wire flasher, than you probably don't have a choice. I am going to go look at the diagram for my new flasher. | | |
#86617 03/03/2005 4:43 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Ok, so I took a look at my diagram and mine can use the 2 prong or 3 prong flasher. Now, with a 3 prong flasher, the indicator on the switch is fed from the third prong. If one of your external bulbs burns out, you will notice an immediate change in speed or failure to flash at all. This tells you that you have a problem.
With the two prong flasher, the indicator bulb is in parallel with the turning lights and if one of the turning bulbs burns out, you may not notice any change in the flashing rate. That would be my guess as to why the three prong is preferred. | | |
