5 members (frogfarmer, baldeagle, Otto Skorzeny, tclederman, Rusty Heaps), 62 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#86572 05/12/2005 6:34 PM
i have a voltage regulator from a 46 gmc and my truck is a 42 chevy. american classic lists a neg ground for the chevy and a positive for the gmc.what will happen if i use the gmc voltage regulator on my chevy
The crew that works on the \'42 --Sara, Hannah and Abby
#86573 05/12/2005 11:42 PM
It will burn out quickly. Voltage regulators are very sensitive to polarity.
Paint & Body Shop moderator
#86574 05/13/2005 3:58 PM
Go to Car Quest or Napa...both will have em or be able to get them quickly. Follow the directions on how to polarize...not hard to do. I put on a new one this winter. The old one was fine...but I needed it for the kid's science project.
#86575 05/13/2005 6:52 PM
thanks for the info
#86576 05/13/2005 8:15 PM
Careful- - - - -regulators don't get polarized, generators do! You'll need the correct polarity regulator to start with, but the generator can work either way with the right polarizing procedure.
#86577 05/13/2005 9:05 PM
Jerry...
Not sure what was on the instruction box...but I had to jump one wire to another for a second or so....I thought it had something to do with polarity or something like that....Not sure what I did with those instructions, but whatever I did, the whole mess is still charging...
Anyway....follow the instructions that come in the box...
#86578 05/14/2005 5:43 AM
It's standard practice to re-polarize the generator when replacing the regulator. Flash the "Armature" wire to the "Battery" terminal for a moment, which sends a jolt of current through the generator armature. Pretty good system, when everything works right. The main advantage to an alternator is an increased charge rate at idle/low speed, and it's self-regulating on current output.
