| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86572 05/12/2005 6:34 PM | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | i have a voltage regulator from a 46 gmc and my truck is a 42 chevy. american classic lists a neg ground for the chevy and a positive for the gmc.what will happen if i use the gmc voltage regulator on my chevy | | |
#86573 05/12/2005 11:42 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It will burn out quickly. Voltage regulators are very sensitive to polarity.
#86574 05/13/2005 3:58 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Go to Car Quest or Napa...both will have em or be able to get them quickly. Follow the directions on how to polarize...not hard to do. I put on a new one this winter. The old one was fine...but I needed it for the kid's science project. | | |
#86575 05/13/2005 6:52 PM | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | | | |
#86576 05/13/2005 8:15 PM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Careful- - - - -regulators don't get polarized, generators do! You'll need the correct polarity regulator to start with, but the generator can work either way with the right polarizing procedure. Jerry
#86577 05/13/2005 9:05 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Jerry...
Not sure what was on the instruction box...but I had to jump one wire to another for a second or so....I thought it had something to do with polarity or something like that....Not sure what I did with those instructions, but whatever I did, the whole mess is still charging...
Anyway....follow the instructions that come in the box... | | |
#86578 05/14/2005 5:43 AM | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | It's standard practice to re-polarize the generator when replacing the regulator. Flash the "Armature" wire to the "Battery" terminal for a moment, which sends a jolt of current through the generator armature. Pretty good system, when everything works right. The main advantage to an alternator is an increased charge rate at idle/low speed, and it's self-regulating on current output. Jerry
