| | | Forums66 Topics128,194 Posts1,057,262 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My '52 216 block, pistons/rods, head, etc. are at the machine shop to get "freshened up". The engine has very little cylinder wear (no lip) and I expect the piston to cylinder wall clearance might be fine. If I dont need to bore oversize, I am debating whether to switch to aluminum pistons (and re-bore anyway) or keep the cast iron pistons and leave well enough alone.
I talked about this in another thread, but wanted to get everyone's oppinion to help me decide what to do. | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | You're spending considerable to freshen up the car you like.The factory thought aluminum pistons and Chrome or Moly rings were a worthwhile upgrade in 1954 and NEVER went back. Small cost to do it now. Yes, I know Moly coated top rings weren't out there in 1954. Cast iron pistons were thought to be more quiet--were more fragile as well as adding unwanted reciprocating weight which adds load to the rod/crank/bearing assembly especially as RPM is increased. While we are at it rebore to the minimum "cleanup" since we are buying pistons anyway. Just a note of interest F--- went to aluminum pistons in 1928 in the model A while chevy stayed CI, I think thru 53 in the 216 and Pontiac still had them in the straight 8 in 54.
Lets hear other ideas.
Bob Taylor
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chev also used aluminum pistons in 1928, (and I believe 27), in passenger car engines.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Gald to see I am not the only person asking about different piston material and whick is the best to use? I have learned that You should probably upgrade to the aluminum pistons. Brian
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I use aluminum pistons in every engine I rebuild, there much easier on the bottom end as Bob mentioned.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | I dont care how much of a purist you are, I'd go with the alum pistons since no one can see them and then use every modern trick out there to try to stop all the leaks-maybe even a pcv valve if you can get creative and hide it. Like them model A and B guys do. Your babbit bearings will thank you! | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Since the inline 6 crankshaft is inherently well-balanced, changing piston weight doesn't induce any nasty vibrations. I'd definitely reccomend an upgrade to aluminum. Less reciprocating weight will make the rod bearings last a lot longer and the acceleration should be better to boot - - - -less inertia. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | So, finally had a chance to talk to machine shop: Cylinder bores are marginal - good at bottom, .0045" to .005" at top. Would probably work fine staying with CI pistons, but I decided to have the cylinders bored and go with aluminum pistons, new rings. I am going to stay with babbit rods as all rods still had two shims under the caps so I should be able to get a good fit on the crank.
What I am doing: Deck block to clean it up. Mill head to clean it up. Hardened valve seats. New valve seals. New camshaft bearings. New crank bearings. New aluminum pistons/rings. Staying with original camshaft/lifters. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd pass on the hardened seats unless yours are really in bad shape and won't clean up. Take the money you save and get a new set of insert rods. You'll be happy with the trade off. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Completely agree. I've read numerous complaints about trouble from hardened seats coming loose, none about problems because they weren't installed. I had the rods machined for inserts on my '38 216. At about 2500 miles a year I probably won't put enough miles on it in my lifetime to know if it was a good choice or not in relation to longevity.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Just out of curiosity, how many miles were on the 216? The wear seemed pretty minimal for a used engine. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Mileage is unknown, but the speedo said about 80k. Someone has been in the engine before, but all bearings, piston, etc are standard size.
I am going to stay babbit as there is plenty material left and it should last a long time. My goal was to not dump a ton of money into the 216 and if it goes bad in the future it will be replaced with a 235. I just dont know how much use the truck will see and thus am not doing the conversion now.
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | ....if it goes bad in the future it will be replaced with a 235. Pay attention to the VIN on your title. Many if not most vehicles pre '56 were titled using the engine number. If yours has the engine number on the title you'll need to re-title following an engine swap.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yep, I'm good. Had to get bonded title and was sure the body VIN was used.
Update: Machine shop said valve seats looked fine and recommended just surfacing and NOT replacing with hardened seats. I agreed. Thanks for the advice.
