2 members (DadsFirstPickup, Stovebolt48), 97 guests, and 1 robot.
Topics128,050
Posts1,055,670
Hello, my brake lights only go on when I have my headlight turned on. This does not seem right, I want them to turn on no matter if the headlights are on or off and even if the motor is off. Can you tell me how the wiring needs to be setup to accmplish this? I have a 46 chevy truck with a cotton braided wiring harness. I just installed a new headlight swtich with fuse from a 47 to 53 Truck and I am sure it is not wired right.
1946 Chevy Truck Export Blue with Black Trim
check a wiring diagram here - the brake lights should get their power from an 'always on' power source, usually a terminal on the light switch, but not the same one as the tail lights ... probably right where the power lead connects to the light switch
I am a new to wiring, do you know where I can get a diagram of the wiring without the voltage regulator? I have an alternator and a 235 engine with a 12 volt system.
On the brake light switch-which is mounted to the engine side of the firewall, inline with the brake pedal-there should be 2 wires coming out the top. One will be going to the brake lights and the other could go to the back of the light switch, this is where the light switch gets power. or you could route it to the ammeter so you know it is getting power all of the time.
....David
Riding in the Passing Lane
If you have a turn switch with 6-7 wires then the brake lights feed off of it. I agree with thee previous posts that the wire to the switch is probably on the wrong term of the light switch.
1972 Chevy c10 Cheyenne Super
