0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, my brake lights only go on when I have my headlight turned on. This does not seem right, I want them to turn on no matter if the headlights are on or off and even if the motor is off. Can you tell me how the wiring needs to be setup to accmplish this? I have a 46 chevy truck with a cotton braided wiring harness. I just installed a new headlight swtich with fuse from a 47 to 53 Truck and I am sure it is not wired right.
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check a wiring diagram here - the brake lights should get their power from an ' always on' power source, usually a terminal on the light switch, but not the same one as the tail lights ... probably right where the power lead connects to the light switch Bill | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | I am a new to wiring, do you know where I can get a diagram of the wiring without the voltage regulator? I have an alternator and a 235 engine with a 12 volt system.
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | On the brake light switch-which is mounted to the engine side of the firewall, inline with the brake pedal-there should be 2 wires coming out the top. One will be going to the brake lights and the other could go to the back of the light switch, this is where the light switch gets power. or you could route it to the ammeter so you know it is getting power all of the time.
....David
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have a turn switch with 6-7 wires then the brake lights feed off of it. I agree with thee previous posts that the wire to the switch is probably on the wrong term of the light switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
