| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My father in law passed away several weeks ago. I was going through his tool selection and found a valve adjusting tool. A handle with a socket and a screw driver blade in middle of socket connected to a knob that you turn to adjust valve. An all in one tool. I am sure many of you know this tool exists, but it is new to me. Cool! | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | During the 1950s most valves were adjusted with the engine running at a slow idle. I still do it that way. The tool you describe was almost a must to turn the jamb nut and the adjustment screw with one hand and use the feeler gauge with the other hand. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | These pop up on ebay every so often but go for more than I want to pay. I too like to adjust the valves with the engine running.
Bruce | | |
