| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Spoke with another bolter yesterday ( vandutch 54) . He found a tutorial on breaking down the 3 piece wheel. I m having trouble finding that ( probably becuase im a computer idiot) . If any one knows where that is could you forward it to me.ive got several of these wheels id like to sell and need to remove the tires. Thank you for the help, I appreciate it. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | There are several videos of multi-piece wheel breakdown on You Tube. The main thing to remember is to get the tire completely deflated so the bead ring can be hammered or pushed away from the rim flange. The tire hammer with the spoon-shaped end on it is a big help here- - - -it is used to strike the tire sidewall just where it meets the edge of the rim, forcing the tire bead away from the flange. If you don't have a dismounting hammer, the base of a bumper jack or a high-lift jack applied to the tire sidewall and lifting against a heavy truck bumper or tractor axle is a good way to dislodge the beads.
Once the tire bead is free all the way around, tap the ring down and remove the split lock ring with a pry bar. Then the bead ring can be removed. Turn the tire/wheel assembly over and knock the bead loose from the other rim flange. The rim should be able to be removed from the center of the tire once the valve stem is pushed back through the slot in the wheel center into the tire. A strong solution of dishwashing liquid and water applied liberally to the bead area makes things slippery and helps the tire bead slip off the wheel. Once the tire is deflated there's no danger to a split rim- - - -the hazardous part is inflating it once the new tire is installed and the rim is assembled. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My advice is that if the tires are junk, use a sawzall to remove the tires in pieces. This makes the job much easier. | | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | A friend and I had a meeting with a wheel yesterday, we won, hopefully the next one will go easier now that i see how they go together. Thanks for all the help/ advise. | | |
