3 members (KEVINSKI, Gray_Ghost, Otto Skorzeny), 113 guests, and 4 robots.
Topics128,100
Posts1,056,513
Members48,448
#863724 07/02/2012 4:05 PM
Does anyone sell used tires-i.e. 7.50-20?
Coker has new ones but the price is outrageous.
Also-can I fit smaller size tires on the split rims; i.e 7.00-20 or 6.00-20?
Commercial tires (big truck) are very expensive. I wanted to put 280/70 19.5 on the front of my Class A motor home. I was quoted over $1k each. I put a pair of 9.50/85 16.5s on for less than 1/2 the cost of one 19.5. I suggest you look for an equivalent metric in a passenger of light truck tire, providing your not hauling any real weight. There are enough 20 inch rims out there for light trucks, you should find something.
Larry
I don't own a vehicle that isn't old enough to drink.
I got two new 7.50 x 20 tires with new flaps and tubes mounted,(after I cleaned and primed the inside of the rims after dismounting) from our local equipment tire guy for $450. But make sure the 20" rims you have are the ones with the lock ring on the outside. the ones with the lock ring in the middle are the widow makers. No one will touch them.
I have been researching tires since I got my truck in febuary. Was going to go the 19.5 route but as said those tires are very expensive. Spoke to my local tire guy and he did 700&750x20 for a local fire department and was getting tires for $160-$170. Since my truck probably only goes 40-45 mph,I'm not very concerned with using bias ply,and this is what works with my budget.
Also the 19.5 tires are smaller so if you go that route your Big Bolt will go even slower. Mine tops out about 40 MPH with the 7.50 x 20s
1 Offline
I bought 6 new "powerking" 750x20. The cost was about $2000.oo including installation. I had the rims powder coated black for an additional $300.oo. They look pretty good. Pictures are on my site.
Marc
<a href="http://s1233.photobucket.com/albums/ff393/fletch41/?action=view&curr
1941 Chevy 1.5 Ton, (soon to be flatbed), dubbed the "USS Coral Sea" which I served on while in the military. wink ~m
wink
~fletch
