4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#864186 07/04/2012 5:07 AM
Former Workshop Owner
Just curious, is there a good reason that automatics don't have a drain plug. I always dread dropping the pan, it's almost impossible to contain the mess.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
couldn't have been too good a reason cuz newer ones do have drains grin likely had to do with only needing to change the fluid if the trans had been abused and then the filter inside should be changed too, so they thought they'd save a few cents skipping the plug .... you can drop a tube down the filler and use onea those little drill powered pumps to suck out most of the fluid so ya don't make quite as much mess .... maybe while you've got it apart you could add a drain plug, just make sure it's the magnetic type
I'm not sure but I thought it might have been to stop folks short cutting the process.
VW did it with their air cooled engines,they stopped fitting a drain plug.
This was to stop people draining the oil without cleaning the filter....
I agree it can be messy,I used a cat litter tray to do mine it helps contain the initial tsunami of fluid.
Funny how even a little drop of ATF on the garage floor can look like a major oil spill disaster!
More pix on Flickr.
My 54 Hydra-Matic has a drain plug...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Riding in the Passing Lane
The early automatics had a drain on the pan & converter also. Hardly anyone used them so they quit putting them on. You can buy a pan with a drain plug or put one in the original pan.
1972 Chevy c10 Cheyenne Super
There were far too many incidents of people draining 10 quarts of fluid out of the transmission, adding 5 more quarts of oil to the engine, and wondering why the car wouldn't back itself off the grease rack.
Now, the vast majority of new cars don't even have a dipstick on the transmission- - - -the fluid is a one-time fill situation when the car is on the assembly line. Fluid only gets changed during major maintenance.
