3 members (Gdads51, 2-Ton, 1 invisible),
103
Mod | | | Forums66 Topics128,137 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Could someone tell me what the recommended weight of gear lube I should use in my transmission and rear end on my 46' half ton. Thanks. Jim- | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 90 weight gear oil. hyoid type for the rear end, and hypoid or non-hypoid gear oil for the transmission. See if someone has reliable recommendation for a modern 90 weight or multi-weight gear oil in both. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tim, I opened the site you posted above. I have a question for you. The Manual says the 1/2 & 3/4 ton trucks left the factory with Hypoid Axel-SAE 90 in the axles & transmissions. The last paragraph says "all transmissions had SAE 90 Transmission or Mineral Oil Lubricant" Is this a misprint or is the Hypoid Axel-SAE 90 and SAE 90 Transmission or Mineral Oil Lubricant the same thing?  I'm restoring a 1946 & this is of interest to me. Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The hypoid gear lubs are high pressure lubs. You must use that in rear ends. GL-5. You can also use it in the trans. You can use any of the multi viscosity as long as it covers the recomended weight. I use 85/140 in everything. These manuals are reprints from the originals. A lot has changed since then in lubricants & recomendations. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
