3 members (Hotrod Lincoln, Wally / Montana, Southerntruck), 72 guests, and 2 robots.
Topics128,060
Posts1,055,831
#86372 12/23/2004 4:20 PM
Junior Member
Junior Member
My 235 in a 50 3100 has a loose gear on the distributor shaft. Not real bad, but the mark jumps around when I have a timing light on it.
The gear seems to be brass and pinned to the dist. shaft. Is there an easy repair? Could I juse JB Weld to secure it?
Auto Zone has a good price for a rebuilt, but they don't have any available.
#86373 12/23/2004 10:43 PM
H Online: Content
Carefully- - - - - -drill the hole in the gear and the shaft out to the next size pin, and install a spring steel roll pin to drive the shaft. For instance, if the drive pin is 1/8", drill the hole out to 5/32" and use a corresponding-size roll pin. The roll pin is spring steel, so it will be plenty strong to drive the shaft.
