1 members (klhansen),
90
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | Does the Borg Warner R10 overdrive transmission governor gear have 15T or other? | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 |
Professional Novice
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I have one I can count this weekend. Fred in CA might also be able to help. | | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | Thanks, Frank for the info. I have both docs and have gone through both without any success to locating my answer. My dilema is that I have a Muncie 319 overdrive tranny which is missing the governor.
I have a NOS governor after much searching, but DO NOT HAVE the gear which mounts on the governor shaft. I am trying to locate one in good condition, but find the ones produced by BW, I have seen already vary in the number of teeth based on the specific vehicle application (vehicle make/model) since BW made these for multiple car makers.
Still looking for some help! | | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | Thanks, Mapleleaf for your help. Can you pass this question onto Fred in CA for assistance? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I am guessing the number of teeth on the gear determine the speed at which the governor grounds the solenoid circuit. As shown in the manuals, the speed of OD engagement varies with different vehicles. I imagine the gear you have will serve you well even if it doesn't kick in exactly at the same speed a Chevrolet spec one would. | | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | So, I could use a 15t gear without damage to either the overdrive unit or the governor? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I thinks so. Study this info on the OD and how it works and I think you will agree. All the governor does is ground the solenoid circuit when operating speed is reached and opens the circuit when speed drops below operating speed. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This got my curiosity up so I pulled the governor off my spare. It has 20 teeth. The gear is stamped IRIOH-73.
Now my thinking has changed. If it were one or two teeth difference it might be OK. From 15 to 20 teeth is quite a jump. Less teeth is going to spin the gov. faster, meaning you will engage OD at lower speeds. And of course hold it in OD at lower speeds as you slow down. I believe I'd look for a 20 tooth gear. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It does indeed use a 20 tooth gear with the markings as Cletis stated. It also has a shaft that fits into a 1/4" hole in the case. The gear that drives the spedo & governor is metal so I doubt that you could use anything but the correct Chevy gear. If it is not matched it could possibly destroy both gears. Ford, Mopar, and Studebaker governor gears are all different from each other and the one you need. BW produced OD's for a wide range of OEM's but the only common thread was many of the internal parts and operational characteristics. Housings are specific to each OEM. Fred
| | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | Thanks for the information. I have the governor...but my search for the correct gear goes on in order to make my overdrive truly complete and correct. | | |
