4 members (baldeagle, Jon G, Oswald, 1 invisible),
57
Mod | | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 69 | I recently aquired a'56 chevy 3100.(6 cylinder) The engine is pretty much shot, as it was ran hot, cracking the head and the cylinders are .039 out of round..A friend of mine gave me a 235(6 cylinder) out of a '54 3100...The motor mounts are different. The '56 has side mounts right in the frontsides of the block and the '54 motor mounts in the front cross-member, in the timing case cover..will it be possible to mount this engine in my truck?..I'm thinking I can drill the front cross-member and make this work.....Oh...I am new to the forum...from Way down in southeast Alabama
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 54 engine will have a much shorter water pump. You may need a fan shroud to keep it cool.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 69 | good point Dave..I did notice that the fan doesn't extend as far out on the '54 engine..I'll keep my eye on it once I get everything together | | |
