| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | I going to purchase a 1956 235 engine... The engine # is 03II870T56Z ... Block # 3837004 ... 1956 ENGINE SERIAL NUMBER List as, Z 15-21-2400 Regular "235" Engine - 6 Cylinder... Will this engine accept my 1954 Hydra-Matic Transmission ? Or would the ENGINE SERIAL NUMBER have to end in " 56XG " for it to work ? Thanks...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | As long as you transfer all the accessories such as the bellhousing adapter, starter, throttle linkage, etc. I don't see any problem with swapping engines. The serial numbers won't match, but the performance shouldn't change at all. If you've got a numbers-correct block it might be worthwhile to save it and have it rebuilt for future use. Jerry
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Thanks again Jerry, I am getting this engine for a great price... Its a runner but do not know how well yet...
Unfortunately my truck does not have the original engine... The one that my father thought was turned out to be a replacement engine, blank engine # on the pad... So counting the engine that is in it now ( 1960 235 ) that makes it the third one...
