1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I had the shift lever out of my 41 4-speed to install a rubber boot. Put it back in without changing anything or moving the truck. When I started out this morning it wouldn't go into 3d gear (I start out in 2d). Any ideas? Is it the reverse lock-out? I didn't have time to check much since I didn't want to be late for work. Thanks, HLW
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | By not going into 3d, I mean the lever moves but the gears don't mesh as if you tried to shift too fast. HLW
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Pulled the tight fitting rubber boot off tonight and it shifts again. HLW
| | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Harold
Looks like you solved this urself appears the boot is somehow keeping you from engaging part of the linkage.
Buzz'n Half Dozen
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I think the boot fit so tightly around the reverse lock-out rod, it wasn't letting it move enough. HLW
