3 members (Rich'sToys, Ponchogl, Peggy M), 332 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#86319 04/15/2004 2:30 AM
My 1955 GMC 500 has the factory tach and transmitter on the firewall I need a wiring diagram for this unit. Any help will be appreciated Thanks Biddaboy :confused: :confused: :confused:
1956 GMC TF 1/2 ton
1955 GMC 500 model (Gumby)
#86320 04/15/2004 11:19 AM
Could it be a Sun made tach? or is it AC. If it's a Sun, you need only 4 wires. The back of the tach has a positive and negative terminals which go the the same marked terminals on the transmitter. Take a good know ground, directly from the engine is possible, connect that the transmitter ground. The remaining wire goes from the transmitter terminal marked dist., take that to the distributer side of the coil, not the ignition side.
#86321 04/15/2004 9:36 PM
Does the transmitter look like a big voltage regulator? If so, there are a couple of Mercury-cell batteries inside that power the transmitter. I remember those from back in the 50's and early 60's when Sun had the electric tach market pretty well sewed up. Good units, but those batteries had to be replaced pretty often!
#86322 04/15/2004 9:55 PM
Jerry ,those batteries are made out of unobtanium these days. I had my vintage Sun tach and transmitter converted to solid state by Williamson Gauge.
#86323 04/16/2004 1:45 AM
Kinda thought so! They were scarce and pricey 40 years ago! When the Sun SuperTach came out, it obsoleted the earlier-type tach with the transmitter, as I remember. It was one of the first solid-state tachometers on the market.
#86324 04/16/2004 4:10 AM
I have a diagram for a Sun EB7A that I can email or go to the link in my signature and I will post the diagram.
My sun tach is in place and doesn't work well, one day it will read 2500 rpm at 55 mph and the next day it will read 3200 rpm at 55 mph. I have been told this is what to expect from a sun tach and the solid state conversion is the way to go.
Truckedup are you happy with the solid state conversion? I received a price quote from Williamson's of $180 including shipping handling to convert my sun tach.
Blaine Dumkee
59 GMC 9314
Fort Smith NT
www.flickr.com/photos/northerngmc/
#86325 04/16/2004 10:59 AM
Blaine, Williamson's did a fine job, the tach works ,well just like a new one, very smooth and steady needle movement. I remember paying about 140 bucks last year, and that was nearly 100 bucks less than other Sun Tach restorers.They gut the transmitter, encapsulate in solid state parts.Williamson's told me of a simple test for the tach head,briefly touch the leads from a single flashlight battery to the + and - terminals of the head,if the needle goes to high scale, the head is worth saving.
Your tach may need the adjustment done to hold the RPM steady.There points inside you can adjust.
#86326 04/16/2004 2:58 PM
I have adjusted the points and the needle is steady, just different from day to day.
I think next fall I will send my tach to Williamson's for an update.
I really, really like the look of the tach in the dash and it would be nice if it functioned as well.
What's ANOTHER $180!
Blaine Dumkee
59 GMC 9314
Fort Smith NT
#86327 04/21/2004 6:09 PM
Do you have a link for Williamson Gauge? Can't find them on "Google"
#86328 04/25/2004 3:09 AM
Blaine Dumkee
59 GMC 9314
Fort Smith NT
