| | | Forums66 Topics128,041 Posts1,055,483 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | I finally found a u joint assembly for my 52 4 speed (enclosed driveshaft). However the u joint has quite a bit of play and I'd like to replace it with a new one before I put it into service. I looked at a few places but the replacement you joints look to have a ring clip to secure them in the assembly (like a normal u joint) but the one that is in the assembly I have now is held in by a ring type flange that slips over 2 of the u joint ends and then bolt to the assembly. Does anyone know where to get a replacement one or is the u joint allowed to be "floppy"? I know this is not acceptable on modern u joints.
Thanks for your time, Wade
52' Chevy 3100 5 window
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you are talking about side play in the cross, that is the way it is made. The torque tube keeps the U" joint centered.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | If I follow your description correctly I think what you may have is a Mechanics joint whereas what you describe as "normal" is a Spicer type. Both use a different type of yoke. The small Spicer types go inside a hole and are secured by the ring you mention. Mechanics are bolted to the flange face of the yoke.
There are Cleveland, Spicer, Mechanics, and other brands so it does get confusing.
