3 members (KEVINSKI, MikeE, joe apple), 102 guests, and 2 robots.
Topics128,034
Posts1,055,551
#8632 03/12/2003 2:06 PM
I had the shift lever out of my 41 4-speed to install a rubber boot. Put it back in without changing anything or moving the truck. When I started out this morning it wouldn't go into 3d gear (I start out in 2d). Any ideas? Is it the reverse lock-out? I didn't have time to check much since I didn't want to be late for work. Thanks, HLW
Harold Wilson
41 Chevy 3/4 Ton
#8633 03/12/2003 2:28 PM
By not going into 3d, I mean the lever moves but the gears don't mesh as if you tried to shift too fast. HLW
Harold Wilson
41 Chevy 3/4 Ton
#8634 03/13/2003 4:34 AM
Pulled the tight fitting rubber boot off tonight and it shifts again.
HLW
Harold Wilson
41 Chevy 3/4 Ton
#8635 03/13/2003 3:34 PM
Harold
Looks like you solved this urself appears the boot is somehow keeping you from engaging part of the linkage.
Buzz'n Half Dozen
#8636 03/13/2003 6:15 PM
I think the boot fit so tightly around the reverse lock-out rod, it wasn't letting it move enough. HLW
Harold Wilson
41 Chevy 3/4 Ton
