0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | The cardboard tubes that the light goes through are in really good shape but the green lens on the end have cracks and holes, I guess from the heat over the years. Looks to me like I could take a piece of green celophane thats close to the original thickness and just replace the lens. Has anyone ever done this and what did you use for the new lens??
Kenny Martin Talladega, Ala Second place is the first loser - Ricky Bobby 1956 Chevy 1/2 Ton | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Either that or see if there is a stained glass shop around and either have them make one or just get a scrap of the green and make your own.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as a TF junkie and stained glass glazier I can point out glass would be too thick to fit on top the cardboard tube and it's pretty unlikely you'd get a piece cut a precise enough circle to glue inside the tube .... there is/was a thin plastic material in a variety of colors that use to be available, I think for sign makers, can't recall the name .... but I've found 'nothing' works fine, a white light there is as functional as green
Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Bill, don't you use a glass grinder to ease the edges of your cuts? When I was working with it we often took off up to 1/8" when the cuts were off. I was thinking along the lines of just cutting something close but over sized and then just easing it down to the right size. Heck I'd do it on a belt sander,I've used one to clean up cuts on 1/4 glass and single pane as well. I'm pretty sure one could easily get it close enough to glue in place, that or less desirable would be cut the tube a bit to accommodate the thickness of the glass. A good camera shop may have gels that you could cut with scissors...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes a grinder or silicon carbide paper is useful to smooth or shape, but those lens pieces are only about 1/2-3/4" dia, even holding with pliers getting a good fit would take more than 1 try, more bother than it's worth .... yes, a camera shop might be the thing for a gel sheet, or someone that deals with colored light projection, like theater folks
Bill | | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | Thanks guys. The glass is way out of my skill set. I'm going to a camera shop and see what I can find. I'll let you know what I come up with
Kenny Martin Talladega, Ala Second place is the first loser - Ricky Bobby 1956 Chevy 1/2 Ton | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I bought a sample gel card on ebay with all colors and cut them to fit for my 56 GMC Turn Sig lenses and gauge lighting (Grn).
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | doesn't classic parts of america or lmc truck have those?
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | geez materman states the obvious solution = GCLL5H, only $5 a pair  Bill | | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | For $5 a pair, that is probably the best solution but I ran into a fellow I used to work with who's hobby is photography. He fixed me up with some scrap pieces of a gel card that I cut out to fit my cardboard tubes. I think this will work fine, but had I ran across the new ones for 5 bucks I most likely would have just ordered them. Thanks everyone.
