1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 60 | The truck I am going to pick up is shy one wheel . Makes it hard to drag up on trailer . Can you help me out with rim size and bolt pattern for a 1946 gmc 1/2 ton . Probably Canadian made if that matters . Thanks
Allan 1946 GMC 1949 Mercury M68
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | If an old Chevy wheel is not available, virtually all Japanese pickups had the same lug pattern as the old Chevy trucks. Nissan, Toyota, Isuzu, Mitsubishi, Land Cruiser, etc. and all their American-badged clones like Dodge Ram 50, Ford Courier, Chevy LUV, etc. have the 6-lug wheels. Most of them are 15", but just to roll it up on a trailer you don't need an exact match. Jerry
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Late 1940's/early 1950's Chevrolet car rims/tires (15") are pretty easy to find locally. You're looking for 6 holes on a 5 1/2" bolt circle. I recently removed the tires from my stock rims for sandblasting otherwise I could have loaned you one.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am now using old Japanese vehicle wheels described by Jerry. They work fine on the rear but provide limited steering-movement on the front (offset problems). As Jerry posted, they work fine for straight forward/backward rolling (and, wide turning).
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Any wheel from a 6 bolt chevy half ton is the right pattern. You could even put a modern wheel on, since you're just putting it on to roll around.
I would also love to see some pictures one you get it home. I'm building a Canadian built 46 GMC 3/4 ton currently.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Maybe earlier trucks have more room but when I tried to mount Avalanche wheels/tires on my 52 they hit the boxside on the rear and the tie rod on the front. If you put some washers over the studs and found some extended lug nuts you might get a modern wheel to snug up enough for rolling it around.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 60 | Thanks for the info . One more rim related question . Are the stock rims hub centric or lug centric and what size centre hole and lug holes are required .
