5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#860168 06/18/2012 9:07 PM
It would seem that my new upper grill mount is about a 1/2" too short. If I pull it in tight, I lose my hood clearance. Is this common?
Does it need to be shimmed? If so, where do I get the shims.
Ralf #862636 06/28/2012 3:34 AM
I guess I'm the only 1 with this problem?
Ralf #862637 06/28/2012 3:39 AM
My guess is you'd get a better response with some pictures and more information. Is this related to the '57 3100 on your profile? Is it the original mount, a used one from a parts yard, Ebay, aftermarket etc.? Did you modify anything while it was removed? Was the truck ever in an accident? Given the limited information you provided and the lack of photographic "evidence", it's hard for anyone to give you a hand with so many variables.
5wests #862645 06/28/2012 4:03 AM
yes, what 5wests said, pics would help - and what's an "upper grill mount"? you mean the bar that ties the fenders together? if that, then yes, body shims might make up the difference, available at any FLAPS, like NAPA, available in a few thicknesses and can be stacked if that doesn't get ugly .... OTOH, if that bar is too short then it's likely the grill mount holes won't match up all the way around on the fenders and splash pan, so you might have something else wrong .... pictures, we need pictures wink
I'd post a pic if I could remember how to do it. Yes, its on the 57. The only thing is, I put a 56 grill in it and associated body work. When I measure the 57 upper bar, it does seem to be a bit longer. I didn't think that would be a difference in the 3 years. If the 56 grill won't fit, then I'm back to using the 57. I just like the cleaner look of the 56. The upper grill bar is a repop. The truck doesn't look like it's been in an accident.
Ralf #862755 06/28/2012 3:16 PM
i just converted 57 fenders to use on my 56 by removing the flat spots on them (inboard of the parking lights) where the 57 grill bolted. the 56 grille and upper bar then fit just fine.
grille and bar
the upper bar was an OEM/original as far as i know.
yes, a 55/6 grill should fit fine, I'd guess the repop part is the problem - body shims might help, but what happens with the grill fit when the fenders pull in so much they crimp the hood? ... have you tried using the original 57 bar? it'll work with the 55/6 grill, just needs the mounting flats covered as Tom did - I've put a 55 grill with its top bar on a a 57 project temporarily, worked fine
