| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 17 New Guy | | New Guy Joined: Jun 2012 Posts: 17 | Were tearing the truck down, and were down to just the engine, bed and some miscellaneous parts. Would it make my life easier when I get ready to put this baby back together to save all the original wiring? (I'm completely retarted when it comes to truck and car wiring, and nearly as dumb when it comes to anything else car / truck related) Thanks Guys!
All in favor, say I. All opposed, Shutup
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | YES! save everything until the job is totally done, you never know when you might need to refer to "how it was", and even if you get a repro harness you may end up needing one silly little thing that's not available new or repro - say like instrument light sockets
Bill | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | is the wiring really tore up? my rule of thumb is if it is held together with electrical tape, baling wire(if your from the south, you know what i mean  ), or is really brittle, REPLACE IT. It will be safer and will be easier for you to deal with in the future, but don't bother if it is perfectly fine.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2012 Posts: 17 New Guy | | New Guy Joined: Jun 2012 Posts: 17 | No. Its all wrapped up in that stuff (Ya know like what a gutters runoff is connected to, that black pipe. but smaller) except the grounds. I was just gonna make a real effort to save the ends. Dumb question - do the wires in between each end really matter?
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i'm sorry......i'm kinda tired, but what do you mean by "the wires between the ends" ?
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jun 2012 Posts: 17 New Guy | | New Guy Joined: Jun 2012 Posts: 17 | Like i know i need to keep the ends of the wires, like where it connects to stuff, but do i need everything in between?
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i don't think so, but it wouldn't hurt to save it all until you get your new wiring kit, just like bill(red58)said earlier.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I'd leave it in until you get your new harness. That way you're immediately familiar with it and its path when installing the new one. ...that's what I'm doing this weekend anyways. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i know what you are talking about. i saved all the "ends" (the connectors, sockets, bulbs, terminals, etc) of the harness with 4-5" of wire left on them in a ziploc bag. I threw away all the old wire in between. As Bill says in post #2, i did find it necessary to 'harvest' a few bits when i rewired. the connector for the temp sensor was one area - the new harness came with a press-on connector for a pin connection and I need a slide-on connector for a T-shaped terminal. i needed the U-connector for the horn out of the bag, too. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I agree with the rest.Save it all until you definitely know you don't need it. You can however, to save time and maybe some agravation, by cutting the harness where it passes through the firewall. That way removing the gauge and interior wireing is a lot simpler.
Drew
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | The only thing I'd reuse might be the unique parts like the dash sockets and such. All the other clips and connectors can be purchased from an auto parts store or radioshack if they're not included. Just remember, your expensive correctly chosen replacement wiring harness is only as good as it's connections and those old connectors are likely to be as brittle as the rest of the wiring. | | |
