| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 37 | It would seem that my new upper grill mount is about a 1/2" too short. If I pull it in tight, I lose my hood clearance. Is this common? Does it need to be shimmed? If so, where do I get the shims. | | | | | Joined: Sep 2009 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 37 | I guess I'm the only 1 with this problem? | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | My guess is you'd get a better response with some pictures and more information. Is this related to the '57 3100 on your profile? Is it the original mount, a used one from a parts yard, Ebay, aftermarket etc.? Did you modify anything while it was removed? Was the truck ever in an accident? Given the limited information you provided and the lack of photographic "evidence", it's hard for anyone to give you a hand with so many variables. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, what 5wests said, pics would help - and what's an "upper grill mount"? you mean the bar that ties the fenders together? if that, then yes, body shims might make up the difference, available at any FLAPS, like NAPA, available in a few thicknesses and can be stacked if that doesn't get ugly .... OTOH, if that bar is too short then it's likely the grill mount holes won't match up all the way around on the fenders and splash pan, so you might have something else wrong .... pictures, we need pictures  Bill | | | | | Joined: Sep 2009 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 37 | I'd post a pic if I could remember how to do it. Yes, its on the 57. The only thing is, I put a 56 grill in it and associated body work. When I measure the 57 upper bar, it does seem to be a bit longer. I didn't think that would be a difference in the 3 years. If the 56 grill won't fit, then I'm back to using the 57. I just like the cleaner look of the 56. The upper grill bar is a repop. The truck doesn't look like it's been in an accident. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i just converted 57 fenders to use on my 56 by removing the flat spots on them (inboard of the parking lights) where the 57 grill bolted. the 56 grille and upper bar then fit just fine. grille and barthe upper bar was an OEM/original as far as i know. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, a 55/6 grill should fit fine, I'd guess the repop part is the problem - body shims might help, but what happens with the grill fit when the fenders pull in so much they crimp the hood? ... have you tried using the original 57 bar? it'll work with the 55/6 grill, just needs the mounting flats covered as Tom did - I've put a 55 grill with its top bar on a a 57 project temporarily, worked fine Bill | | |
